@Hardy sorry about that, we have many implementations on many different wearable platforms and those can slightly differ in behavior.
In general the idea is to use gentle vibrations which find the minimal intervention needed to wake you up to make the experience more pleasant..
At the moment we start with a short single vibe at alarm start with a 30s delay - another vibe 20s - another till this becomes constant vibration.
If for your ringtone sound is faster that vibe for waking you up there is a simple fix, just put a e.g. 1 minute delayed sound start on the alarm..
We will look into this and see if we can fine tune the pattern for a better experience in your case but as always if you do such changes you can expect a lot of negative feedback from users used to this pattern who will find the Tizen platform vibration too strong..
I cant get the alarm to go off on my watch. GW4. I have the beta version installed. I am unsure what companion apps I need to have installed. There is a galaxy gear add on and sleep as android unlock app. I had both these and it didnt work. Then i uninstalled both and it still doesnt work. Any help is appreciated.
I got it to finally alarm after updating the beta version to my phone. The snooze screen does not come up automatically and I have to select the bottom of the watch to get the snooze screen. Is there a fix to this? I also am not a fan of the slow starting vibration. Having changeable options would be best. Thanks
@Haffoc many thanks, in fact we plan this, although health services are getting more and more strict and for instance Google Fit does not more allow to read any data without an expensive auditing process.. so I expect Samsung will follow soon so honestly it is a question whether this still makes some sense. Also I do not think we will get the detailed data - SPO2 every second which we need to calculate any Respiratory Disturbance which is why we are doing this..
Same story here, and the alarm is no longer working.
Given that I have also had the always on display for custom watch faces stop updating, I’m guessing that Samsung has started Doing Something to apps running while the screen is off.
Hopefully soon either Samsung will fix it, or a workaround can be found.
I’ll try that. I also found it doesn’t happen if I’ve unlocked the watch right before bed. I suspect the watch getting locked stops it sending the data to the app. Hopefully the background setting will resolve that.
Made an account just so I could say thank you! Tried it out last night and it appears to have fixed the problem. Also made that same change for Watchmaker and it seems to be a fix for the “3rd party watchface not updating” bug too.
I just got a Watch 4 Classic, and I haven’t been able to get it to consistently share heart rate or o2 with SAA. If I check SHealth, I can see that both were tracked all night, but my SAA data shows heart rate was only recorded for part of the night, and o2 was not recorded at all.
Any ideas what I can check? I’ve already made sure that sleep tracking was allowed to run in the background.
Hello @Lisa_Clarke, in the screenshot I see that Sonar was also used for this session, so my theory is:
Something happened short after 12:00 - mayeb the phone rebooted, maybe your phone did kill the app (see https://dontkillmyapp.com/ ), maybe the new battery optimization algorithm stopped the app on the watch, we were abel to recover the sleep tracking process, but did not manage to connect to the watch anymore and fallen back to Sonar. The phone was probably not positioned properly to do a proper Sonar tracking so this is why you see mostly no light sleep after that time..
Can you please check https://dontkillmyapp.com/ for any non-standard battery optimization on yoru device?
Can you please check the Galaxy Waar app on yoru phone.. look for Sleep as Android and allow “Background processing”? This is discussed on the Galaxy Watch 4 thread linked from this thread.
Also please consider using menu > report a bug to give us more details on the issue..
Thank you for replying. I had already checked all of those background battery settings. I’m not sure what happened, but everything was fine tonight, so I guess I can chalk it up to being a fluke.
Hi, i’ve just bought a GW4 and i’m using this app since so many years ago (because is wonderfull) but i wanted to record the SPO2 due to I have some apnea. The GW4 is able to record HR but does not store anything from SPO2. Which is the state of this feature. I’m running the latest wear os and latest beta of the app.
Hi, the SpO2 sensor is currently closed for 3 party apps. If Samsung lifts the limit and allows us to register on the sensor, we can adjust the companion app for reading the data. The API is open, so it looks like it is only a temporary limit.
I tried this a few months ago and it worked well. However, after a firmware update, Samsung seems to disable this option for 3rd party apps. I’m not sure if it’s only me who cannot enable it now.
Hello.
First, I’d like to thank for all the wonderful job you’re doing. This app is really the best there is.
Second, few questions:
Are there any news regarding the SpO2 tracking on GW4?
Any thoughts, if HRV tracking would be possible on GW4?
