It appears to work for me as well with both of the applications updated to the latest. Thanks so much!
Appears to he working again on my Ionic here. Will test tracking tonight. Thanks!
The tracking with the ionic worked as expected.
But it uses 10-20 % of battery per night, and thatās why Iāll stay on phone tracking.
I donāt know if something like that is fixable
Connecting and tracking works as intended again on my FitBit Ionic. Thank you very much for fixing this
I cannot see the heart rate⦠is heart rate monitored or does it require another setting?
@jiri-urbandroid I can confirm, that now it is working like expected with fitbit version 1.13 and companion App 1.7.
I will still keep on testing. Thanks
No, it doesnāt workā¦
Yes, thatās an issue.
If you are implying to the earlier mentioned 10-20% battery consumption; this is relatively normal. This was an issue with my Ionic too.
Now I have changed to Versa, which seems to have more battery capacity. And the new Versa 2 have even more capacity. Just a tip. ![]()
PS. I suppose the Ionic have more consuming applications and functions.
Works fine with my Versaā¦
Have you activated it?
I checked with (and without) āHeart rate monitoringā option in Settings->Wearables (it does not list FitBit here so that already makes me suspicious). If I select heart rate monitoring the fitbit app shows āTrackingā¦.(HR)ā but there is no heart rate indication and graph like with my Mio band as I used to see before.
Also the sleep diagrams posted in this topic do not show heart the rateā¦
This is my reality, about 90% of all nights I get flatline/no connection. Sometimes it reconnects, but often it stays off for the rest of the night and therefore breaks smart wake-up.
Has been like this with the latest few versions.
Also, it would be nice to be able to see current heartbeat in companion app on watch.
Are you on the latest firmware that supports SDK 4.0? It used to be like this before Fitbit completely rewrote their communication stack for the new SDK, but Iāve had it reported that some watches still donāt have that update.
Your question got me googling, not easy to find which versions of firmware matches SDK.
But it seams like Iām running latest.
But I also have had problems with screen being unresponsive and laggy, I googled that to and realized that my clockface probably wasnāt compatible with 4.x. Have changed to stock and have no lag atm. Will see how sleep monitoring works tonightā¦
Last night I had same problem like @Humlan described.
I donāt know what is exactly wrong. First night was working well and yesterday I could not connect.
I think weāre getting closer! These are my observations so far:
- One night all OK!
- One night flat lines after a few hours.
- Last night some heart rates (varying between 15 and 300!!) but no sensor movement registration at all.
- Sometimes connection issues (Sleep app does not connect and keeps saying āwaiting for fitbit to connectā). A phone reboot solves this.
I am on android 10 (build qq1a.200105.002)
Fitbit Versa 35.70.714
That graph is the light level - not heart rate. Heart rate is a thin red line with numbers in red circles.
