From Julius on 2015/07/29 14:07:36 +0000
you have alarms set in the app for normal work days, for example I have 1 for 7:30 (AM) and now I have vacation from work for 3 weeks. Now my idea is an function to turn off the alarm for an amount of time for vacation, for example 3 weeks, now if I do that the alarm gets turned off and after 3 weeks it turns itself back on, this way you can’t forget the turn it on and thus you can’t be late at work ![]()
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/9074869-turn-off-alarm-for-vacation
A post was merged into an existing topic: Add a Vacation mode
UPDATE: the topic was merged with other similar suggestions to “Add a vacation mode”.
