Is the Xiaomi Mi Watch supported by Sleep As Android?
Cheers!
Cheers!
Hello @Frantastri, this depends on Tools & Mi Band or Notify & Fitness - the apps which do all the Mi Band and Amazfit integrations and they also integrate with Sleep as Android though our Wearable API..
I tried to check their Play Store description for Mi Watch but did not find it I think latest news from Zdenek Horak @ Tools was he is adding support for:
So not sure about the Mi Watch yet..but please correct me if Iām wrong..
I donāt think it can be integrated since both Mi Watch and Mi Watch Lite use Xiaomi Wear, a completely different app. It would be nice if those devices are added as not supported devices - someone could find that information useful.
Not being able to use Sleep as Android is the main reason why Iām not gonna buy a Mi Watch. It looks great, though.
@Frantastri we keep a list of supported devices here:
https://docs.sleep.urbandroid.org/devices/wearables.html
I guess we cannot keep a negative list of not-supported devices as this would be too overwhelming, so sometimes it can happen that a device which is not listed here may work, but it should not happen that a device not working will be listed hereā¦
It makes sense to me. I just was used to the old documentation site, but I have just checked that in the new site things work differently.
Hi Petr, when testing the sensor(via settingsā>wearable) the interval appears to be 10s.
Is that the same during the sleep recording?
So whatās the proper way to start a sleep session using a Fitbit Sense? I had a MiBand with Notify and Fitness and all I had to do was start sleep as android and it would vibrate the MiBand.
Now, I downloaded the app on my Fitbit and started it. Then started Sleep⦠Got a āconnected to FitBitā message and I could see the bar at the bottom move and the HR was visible. So I went to bed⦠but then it seemed to only track for ~1h or so, I get a blank red bar for the rest of the night. Also, on my phone, when I stopped everything, I had a āwaiting for fitbitā notification that wouldnāt go away.
Any tips?
I tried starting my night on the phone then launching the app on the Fitbit but I got a error message saying āplease contact supportā.
Also⦠it seems that quitting the app on the fitbit isnāt reliable. I hit the button, I get a Yes/No prompt to quit. If I hit āyesā, it vibrates but stays there. Is that normal?
Do we know if Sleep as Android is going to work with the new Sleep Breathing / SP02 functionality of the Mi Band 6? Or is that largely down to if one of the tools suites adds support?
@Textuality it seems Mi Band 6 does not provide SPO2 directly only the raw data from LEDs, so at this stage we are in the phase where we tracked some time with Mi band and one of the Berry MED oximeters and we are trying to find a good calculation for SPO2 on the Mi Band.. we will if we can bring this to some production state.. it also needs to be supported in the Mi Band apps..
First night with the new Mi Band 6 didnāt go particularly well anyway. Completely failed to record any SPO2 data (in its own app) though I definitely saw the sensor active a few times, and Iāve never looked before, but apparently the tracking it does is awful. Reckoned I was awake for 5 hours out of the 7 I was in bed for!
Iāve encountered the same problem, @llavalle . Assuming itās been linked/paired properly, you need to:
I notice that any small deviation from this (e.g. starting tracking in the phone app first) causes it to fail silently. Added, if I start them in the wrong order, then try again in the correct order a short time later, it still produces the bug. (Iām guessing this is because both apps need to be restarted).
It also regularly seems to drop tracking partway through the night for no reason that I can tell.
And I get the same problem youāre having with quitting the smartwatch app. Trying to exit, turning off the screen for a while (30+ seconds), and then turning the screen back on seems to clear it.
Itās a little disappointing to be honest as itās driving me away from Sleep as Android after 6+ years of use! I find the Fitbit sleep score & benchmarks are just much, much easier to make a daily or weekly comparison. The only things keeping me using Sleep as Android are the snoring % score and an IFTTT event that turns on my lights when the smart period begins.
Yeah - Iāve figured that itās the best way to work. Found my issue though : I randomly get a āerror, contact supportā message on the watch app when tracking starts on the app (and pushes the alarm time). When it does that, I need to quit the app and restart.
My problem was that I was using delayed start on the app - so that āerror, contact supportā message would come up when Iām almost asleep, after that delay!
There was a new version of the sleep app on Fitbit in the last week - hopefully itās better⦠but Iām with you on this - Iām tempted to just use the Fitbit for tracking but my problem is that :
1-The Fitbit canāt RING after a few minutes of not waking up. Vibration works for a few days but I end up getting used to it and not waking up
2-I use Sleep to schedule my sleep time according to my wakeup time (which varies a lot)
Another couple of nights with the Mi Band 6 and Iām thinking Iāll switch back to the 5. Seems to be missing a number of hours of heart rate data, and it canāt be how Iām wearing it given itās the exact same band / size as the 5!
Hello, Iāve not clear understand this app, I have a Ticwatch Pro 3 gps and already installed the app on phone and on the Ticwatch. Automatic sleep tracking will start automatic or have I ho open the app on the watch for start tracking?
Many thanks to all
Hello, I have a Amazfit bip U watch, with gadgetbridge (Zepp app uninstalled for privacy reasons.) I see that pebble used to be supported via gadget bridge. Would this also be possible with the bip U?
It looks like the Bip U does work with Notify for Amazfit.
I donāt have the official app, but I am using this and Gadgetbridge at the moment.
Please, can you add support for Umidigi UFit?
Hello, it is unrealistic for us to integrate such device.. Devices like Umidigi ale totally closed - not made for any 3rd party integrations - usually only their proprietary app works with the device.
We can integrate open devices which provide an API we can either access the device sensors through BT characteristics or implement on device apps which collect sensoric data and send them to the phone..
Some integration with closed devices like Mi Band is possible thanks to bluetooth sniffing geniuses like Zdenek Horak of Tools & Mi Band, but this is hard work, reverse engineering a closed device can take moths with uncertain outcome.. This really makes sense only for devices which there are hundreds of millions sold world wide..
Will there be support for the OnePlus Watch? I know itās not wearos based but was just wondering if there was something imdown the pipeline for it by chance?
Hello, I am looking for option to use wearable SAMSUNG Galaxy Watch Active 2 with Sleep as Android.
Is there any feedback about this combination?
