Release notes for BETA
News for BETA updates
All versions are available at Download - Sleep as Android, in case Play Store is not showing you updates yet, or you would need to downgrade.
  • Improved lullaby volume adjusting with Sonar
  • Fixes in Swedish translation errors
  • Remembering the last open tab in the Tabbed home screen mode
  • More smaller bug fixes
  • Fix for predefined alarms ringtone - not being application settings
  • Fix for permission names in Cezch
  • Fine tuning apnea alarm thresholds
  • Fix for mute ringtone when using lucid dreaming
  • Fix for Sonar not reverting volume if sleep tracking is hard killed by the system and restarted
  • Fix for inconsistent “skip next” text in alarm list
  • Fix for Settings > Alarm > Disable screen orientation changes settings
  • Improved look of alarm screen in landscape on phones
  • Improve CAPTCHA cheating protection though Accessibility Service
  • New walk-through tutorial for Captcha cheatim permissions - If you want to prevent any cheating of Captcha please enable Settings > Accessibility service >Sleep as Android
  • Fix for white edit filed on note dialog in sleep tracking screen on older devices
  • Several bug fixes
20220218
  • Visual improvements in on-boarding screens
    -More color aligned backgrounds and images
  • Nicer Droid images
  • Pause +5min option in sleep tracking screen when not using noise recording
  • Media Session support for lullaby playback - can be controlled from the quick settings, Wear OS watches, the assistant…
  • Show year info even for shorter period chart views
  • Fix for white edit field on note dialog in sleep tracking screen on older devices
  • Several bug fixes
20220303
  • Fix for a rare crash when Unlocking the app
  • Tst button for IFTTT and related fixes
  • Varios smaller bug fixes
20220315
  • Fix for a widget size regression
  • Fix for reschedule alarm notifications texts
20220322
  • Preview dialogue for Captcha
  • Calendar integration: Fix for reschedule alarm notification texts
  • Fix for DropBox and Drive automatic sync
  • Fix for rare crash when Unlocking the app
  • Test button for IFTTT and related fixes
  • Various smaller bug fixes
  • Updates in Swedish, French, Portugues, Spanish (big thanks to all our contributors!)
20220421
  • Support for Android 12 API level
  • Fix rare dismiss of snooze alarm failure
  • Fix for crash Captcha cheating protection when Draw over other apps is off
20220428
  • Fix for using full potential of Accessibility Service for Captcha cheating protection
  • Fix for compatibility issues with SleepMask USB version and Android 12
  • Update in Farsi translation (thank you!)
20220503
  • Fix for NFC Captcha regression caused by targeting Android 12 API level
20220505
  • Potential fix for Lullabies over Spotify and audio focus stealing
  • Few crashing bug fixes
20220510
  • New Spotify integration using remote play: more reliable, works for Spotify users, should always play the selected playlists
  • To use new Spotify remote play, you need to re-authenticate in Settings > Services > Spotify, or tapping on the news card
  • News card about the new Spotify integration
  • Better NFC handling in NFC Captcha on new Android versions
  • Fixing volume indicator in alarm when directly accessing system volume (e.g. Spotify)
20220511
  • Fix for Sleep time estimates regression caused by Android 12 API targeting
20220513
  • Fixes for crashes related to automatic sleep tracking and Sleep Phaser because of Android 12 API level target
20220516
  • Fixes for starting service from background limitations in Android 12
  • Fixes for pair tracking on Android 12
  • Fixes in Sleep time estimates issues related to Android 12L + 13
20220517
  • More fixed in sleep time estimates issue related to Android 12L + 13
  • Updated library versions for many libraries
  • Potential fix for Nearby API incompatibility with Android 12
20220519
  • More fixes
