Release notes for BETA
20220531
  • Fix for Spotify playback to continue playing after a quick snooze/dismiss
20220603
  • Fix for Spotify login for Facebook
20220608
  • Integration with our app Lis10 to add guided fall asleep meditation to your lullabies
  • You can enable meditation in Settings > Lullaby > Meditation
20220609
  • Workaround for CAPTCHA cheating protection crash on some Samsung Android 12 devices related to accessibility service
  • Fixing volume indicator in alarm when directly accessing system volume (e.g. Spotify)
  • Better Spotify and meditation lullaby
  • New Spotify integration using remote play: more reliable, works for Spotify Premium users, should always play the selected playlist
20220613
  • Fix for odd/even weeks confusion
  • Lis10 meditations now support German and Spanish
20220614
  • Sleep duration goal in home screen shortcuts now triggers without bedtime notification time
  • Fix for alarm widget to show day when at least 24 hours ahead
20220615
  • Option backup files in a shared directory in Settings > Privacy > Local backup > Storage path
20220617
  • Experimental PineTime support (InfiniTime 1.9.0+ firmware is required)
  • Supports: accel sleep tracking, heart rate, lucid dreaming, and anti-snoring, alarms
  • Missing: awake detection, better alarm
20220621
  • Fix for PineTime HR tracking
  • OPtion to skip rating screen after tracking in Settings > Stats
20220624
  • Better handling of gesture navigation on rating screen
  • Fix for showing PineTime on Smart watch connect screen
20220627
  • Fix for gentle volume increase for Spotify with the Last song option
  • Stop and Pause / Resume actions from sleep tracking notification
20220628
  • Fix for a recent regression which bring Sleep to the front when dismissing an alarm from notification
  • Fix for a recent regression in webhooks
  • Option to only automatically start tracking when on charger (this is by default always ON for Sonar)
  • Option to allow basic authentication in webhooks automation
  • Stop action on sleep tracking notification stops and saves tracking directly
  • Fix for crash in barcode scanning
20220715
  • Gentle vibration n PineTime
20220719
  • Toggleable graph legend_ allows you to select exactly the view of your data you want
  • New landscape view for graphs
  • Better graphs for tablets
20220720
  • Improved graph toggle for landscape mode
20220809
  • Showing data in Sleep score or Charts even with recent gap in data
  • Fix for not immediately terminating tracking when tapping sleep tracking notification
  • Fix for charging requirements in automatic sleep tracking when sonar as well as wearable is selected.
20220816
  • Material Design V3 dialogs everywhere
  • Small styling tweaks
  • Settings category contextual help (?)
  • Sleep tracking settings less bloated
  • Slovak and Greek translations
20220817
  • More Material Design V3 redesign: app settings, menu drawer, alarm settings
  • Material Design V3 fonts styles
20220818
  • Using Material Design V3 text fields
  • Design tweaks in alarm card and alarm list
20220829
  • Several crashing bug (introduced 20220818) fixed
