Organize alarms (move or group)
From Anonymous on 2014/10/25 09:51:01 +0000
1) I would love to be able to just put my alarms in order. This literally means just moving the alarms around. This could be done by putting them in order with numbers or names, I don’t quite care how. That is all I’d like. This is a very lovely app, thank you.
  1. The ability to group alarms would be helpful for those of us heavy sleepers that have to set minimum 5 alarms. Collapsible and nameable folders would help organize the alarms. This allows us to have groups of alarms, and enabling/disabling all the alarms with one tap of the group’s on/off button. This would also be beneficial for those that are polyphasic sleepers that can layout all of their alarms for both their main sleep and later supplemental naps in one place.
    Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6609359-organize-alarms-move-or-group
3 posts were merged into an existing topic: Custom alarm groups
Moved to the Custom alarm groups feature request.
