It would be nice to have additional options for the dismiss alarm screen, such as swipe gestures to dismiss or snooze.
You can make dismiss still require a swipe and hold to replicate the existing long press.
Support conversation
Hi
I can see that this has been requested before in 2018 ( Alarm slide to dismiss/snooze instead of button ) but was at that time dismissed with the reason “we try to avoid any custom components on screen“.
Because I think it is an important feature (to avoid missing alarms because off ‘pocket dismiss’) I would like to request this feature again and in that context I also want to refer to that the default google alarm clock quite recently has added this feature (if activated by the user in the app).
(One reference (and also my own real life experience as well
https://9to5google.com/2026/01/22/google-clock-alarm-swipe-dismiss/
I hope this does make this request more ‘acceptable’ for ‘Sleep as Android’
Best regards
Frank
I would love a different snooze/dismiss screen, more similar to the stock Android clock; where you swipe up to dismiss and swipe down to snooze.
You can still require holding on the up swipe to dismiss (similar to how it is now) and you can still have some buttons on the bottom to select a longer snooze time.
