Add some way to actually import your saved settings (prefs.xml)
As in title. I recently upgraded to a new device and exported settings and data on the old one.
When I tried loading the backup (Backup → Import data) it restored the sleep data perfectly fine but ignored the settings. I have been unable to find any mention of that actually being possible in the app or indeed the knowledge base which is disappointing.
Oh, touché about the knowledge base! I’m adding it there right now.
So, how to that: go to settings and search for restore settings. That’s the option you need.
Thank you for your answer. I didn’t check under Dangerous options, it worked flawlessly.
This topic was automatically closed after 5 days. New replies are no longer allowed.
The Restore settings option has moved to Settings > Privacy
