Widgets - Sleep as Android
Starts a tracking and reminds you when to go to bed with colors.Two hours before the bedtime, shows the countdown. When you reach bedtime, the widget turns red as a warning that you should go to sleep ASAP. Tapping on tracking widgets initiates sleep tracking.
This is a companion discussion topic for the original entry at https://sleep.urbandroid.org/docs/ux/widgets.html
