Weather Widget On Lock Screen
I recently got interested in having a weather widget on my lock screen since I check the weather pretty often throughout the day. I’ve been looking into different options and customization features, but I’ve got some questions about how it all works. Does anyone know if having a constant weather update on the lock screen affects battery life significantly? Also, I’m wondering about accuracy - how often does it actually refresh the data? Sometimes I notice weather apps can be a bit off compared to what’s actually happening outside. I’m particularly curious if there are any widgets that can show detailed info like humidity and wind speed right on the lock screen, not just basic temperature and conditions. Has anyone found one that’s both good-looking and reliable? And what about different themes or color customization options? Would love to hear about your experiences and recommendations. I’ve seen some cool setups in screenshots, but I want to make sure I’m making the right choice before committing to one.
(I’m using the latest Android version, if that helps with suggestions!)
