I’d like some wearable advice. I’d love to get HR and possible 02 readings, but my main concern is just a more accurate sleep tracking and being able to auto-start tracking if I forget. Comfort is another big concern. I was hoping the Oura ring or some other ring tracker would be a good option, but it seems Oura doesn’t provide a bluetooth API and might turn off bluetooth while sleeping and the only other ring I saw was the 02Ring pulse ox which is noted as having a bright display that doesn’t turn off and is potentially buggy since it’s a reverse engineered API.
Any suggestions on the best wearable or device to use with SaA to get at least the main above needs covered?
