Wake up check (notification)
When creating a new feature request, don’t forget to vote after submitting it!
I like this feature of another alarm app where it sends a wake up check notification after a preset time once the alarm has been dismissed. It requires me to tap the notification and confirm I am awake, else it will make the alarm ring again and then do a wakeup check notification again.
This is great because unfortunately I have gotten so good at the captcha, I just do it to dismiss the alarm and fall back asleep. I could choose a new harder captcha, but at the same time the wakeup check is a nice feature for peace of mind. Also prevents for example unintended falling back asleep even if somebody woke up for at least a few minutes but was very tired.
Hello, we have a CAPTCHA task to prove you are woken up by the alarm. If you happen to dismiss the alarm, solve the CAPTCHA task, and then fall back to sleep, the CAPTCHA is not effective enough for you. You can combine more tasks with Random and Multi CAPTCHA (from the free extension pack).
The ultimate CAPTCHA is QR or NFC CAPTCHA. You can put the barcode in a different room - so you are forced to get up in order to dismiss the alarm. You can even use more codes and have them all scanned to dismiss the alarm.
Hello @Chee_Rex & comp. .. sorry this feature took longer, but we have prepared a version of the “Wake up check” feature into current BETA version 20240728.
This APK is available:
https://sleep.urbandroid.org/wp-content/uploads/release/sleep-20240728-beta-release.apk
This version should also soon be available from the BETA channel on the Play Store..
For wake up check you specify two options: Check after.. Time to confirm
Check after means how long after the alarm a notification is shown which asks you whether you really are awake..
Time to confirm the the time you have to say YES, otherwise the alarm will re-activate..
Does this address your feature request? Are missing something in this new feature?
Many thanks for your feedback and for proposing this.
Petr
Dear Petr, sorry for the long wait for a reply from me. Yes it is what I was thinking of and I am grateful for your work into it (and the team’s work) !
I have some feedback on the wake-up check. I tend to miss the wakeup check notification, even if I am awake, then the alarm goes back off so I have to dismiss it. Then that triggers a future wakeup check which I might also miss, since it is a simple notification that is easy to miss.
And I also think the wake up check should have an option to be temporarily disabled if the phone is traveling in a car, in case I am driving and the wakeup check keeps going off, or otherwise the captcha should be disabled if the car is moving.
(Perhaps this can be implemented in a simple way with Bluetooth connection detection, or Android’s built in driving detection)
What do you think about my feedback?
Hello @Chee_Rex you can configure the notification in Settings > Apps > Sleep as Android > Notifications > Wake up check.. you can make it sound a long high volume ringtone and ad vibration etc so that it is not easy to miss?
