Detailed description of the problem: Wake up check does not repeat. It only shows once, even with 2x/3x/etc repeat is selected.
Steps to reproduce: Set an alarm with wake up check repeat >1x
Version of Sleep as Android: 20260121
Hi @Jackomac,
Could you please add more details? Do you confirm the wake-up check notification?
Yes, I confirm the wake-up check notification but then nothing happens after.
Is this expected when repeat is set to 2x or 3x? Or am I misunderstanding the function.
The repeat only happens if you don’t confirm.
If you confirm, it means you are awake, and the alarm is no longer needed.
If you don’t confirm, it means you are not awake, and you need the alarm, so it will repeat (2x, 3x… depending on your configuration.
Thanks @lenka-urbandroid
Seems I misunderstood what the repeat function did! That’s all clear to me now.
This thread can be closed as this is not a bug report, but user error! ![]()
No worries ![]()
Just one last question - is there anything we could do to make it clearer in the app? A better description, perhaps?
I think it would be great if the Documentation was updated to include a description of the Repeat function. Right now it’s missing from the Wake-Up Check info.
Thank you for your help!
