Hallo ein Wake Up Check also eine Erinnerung das man wach ist wäre gut.
Liebe Grüße Christian
Hello @Christian_G . … sorry this feature took longer, but we have prepared a version of the “Wake up check” feature into current BETA version 20240728.
This APK is available:
https://sleep.urbandroid.org/wp-content/uploads/release/sleep-20240728-beta-release.apk
This version should also soon be available from the BETA channel on the Play Store…
For wake up check you specify two options: Check after… Time to confirm
Check after means how long after the alarm a notification is shown which asks you whether you really are awake…
Time to confirm the the time you have to say YES, otherwise the alarm will re-activate…
Does this address your feature request? Are missing something in this new feature?
Many thanks for your feedback and for proposing this.
Petr
