Hi.
I just switched from old Galaxy Watch 3 to Galaxy Watch 8.
On the old watches, the Sleep as Android worked great, and as the alarm rang, the watchface lit up, immediately giving me the option to snooze or end monitoring etc, even in DND and Sleep routine.
On the Watch 8, it stays off, forcing me to press buttons, discard Sleep routine app and search for the Sleep app to control it from there.
Can the WearOs version work the same as the Tizen one did?
Second, when I dismiss the alarm in the watches, the Sleep as Android on the phone quits as well and don’t show me the sleep summary.
Any help is greatly appreciated.
HI @Michal_Sitanc, Wear OS and Tizen are completely different platforms with different options for developers and apps.
For example, the Wear OS has not implemented Draw over other apps permission yet, so the app is not allowed to launch a full alarm screen. This means that at the time of the alarm, the system allows only a notification you need to tap to allow the alarm screen.
Do you have this alarm notification on your wearable during the alarms?
When the alarm is dismissed, the behavior of the app on the phone depends on your configuration in Settings > Personalize > Morning screen > Morning screen.
Either the app can open the Morning briefing overview, open the graph, open the main screen, or close everything).
