I have a Motorola g6 mobile phone, Android 12, and Sleep as Android, paid version.
App is set to use the motion sensor and lullabies.
On waking up, the sequence is:
- Alarm sounds. I press snooze.
- Some notification arrives, and it sounds (so DND was disabled already).
- Alarm sounds, second time. I press dismiss.
- I try to close the app
- I unlock the phone
- I press the volume up key, and I see that it is set to zero. I think it is the multimedia volume.
This happens everyday. I noticed the problem when the phone own alarm, which is set to an hour later, for backup, would not sound. Or if I tried to play a youtube.
Ideas? Some configuration? Is it a bug?
