Hey, please add the feature to prevent volume down by user when the alarm is ringing m alarmy has that feature where you cannot reduce the volume while alarm is ringing. Can i do that in this app?
Regards
@Deeraj_Singh_Bhau please just double check that you have enabled Settings > Alarm > Gradual volume increase … by default this is set to 1 minut, so even when you would be reducing volume o zero in 1 minute it will get back to max…
