Hi there,
I’m an enthusiastic user of the Sleep as Android app. It’s fantastic! My sleep quality has improved, and thanks to the smart alarm, I’m usually able to get up more easily in the mornings. Great work, and thank you so much for this amazing app!
I have some suggestions that I hope you might consider:
I use the delayed sound feature as I control my Philips Hue lights for a sunrise effect. It would be great if there was a custom setting for the delay times (e.g., delayed alarm, vibration, delay for lucid dreaming, etc.), where users could input a custom value (e.g., 1–1000 seconds), instead of being limited to the default options like 1 minute, 3 minutes, 6 minutes, etc. The current intervals feel a bit too large for my needs.
Regarding the lucid dreaming feature, it would also be helpful to have an option to limit its activation per night. For example, a maximum of 1x, 2x, 3x, etc., per night. At the moment, it seems to activate a bit too often for me.
It would be amazing if you could look into these suggestions and consider implementing them.
Thank you very much, and happy holidays!
Best regards,
FK
