Hi!
I’m currently using your app as my morning alarm. In fact, it’s been a long time since I started using it. At first, it always waked me up. But my brain started to adapt. Now, i am able to automatically turn off the alarm, and almost without opening an eye. The thing happens that way:
The alarm rings. I can’t escape the app and if i go back to my phone menu (middle button in the lower part of my phone) and unlock it again, it goes back straight to the alarm app. I can’t turn off my phone IF i’m on the app.
The if is in capital letters for a reason. If i go back to the home screen (the one you get once you’ve entered the PIN code and before entering your password to unlock your phone - let’s call it the “first menu”) and try to turn off my phone, i can.
So my question is:
Is it possible, once the alarm started to ring, to even prevent the phone to be turned off, and even if we go back to the first menu?
Your app is great and i only need this to make it perfect for me.
Thanks in advance.
Regards.
Manrieve.
