In my room, there are two people, each with one bed. And we’re both using Sleep as Android.
The problem I’ve noticed is, even if we set the same alarm time, one of us is likely to be awaken up during a deep-sleep period by the other’s alarm.
Can there be any way to mitigate/solve this issue other than using smart band alarms, e.g. by syncing the two phones and make the alarms ring when it is a time good enough for both of the roommates to get up?
Thanks!
