Twilight connection
From Björn Walz on 2016/03/29 00:13:14 +0000
Possibility to Connect Twilight directly to Sleep ad Android (especially turning off the overlay in the morning as soon as the alarm goes)
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/13188306-twilight-connection
From Björn Walz on 2016/04/02 00:22:54 +0000
A few more features would be really great. For example that you could define how long before your ideal sleeping time the overlay should activate and what should happen on days without an alarm set.
