So my other half has to have the TV on while sleeping. I wake up and listen to my sounds and while it’s recording movement and snoring, it records the TV all night. I can not figure out what to change on the sensitivity, but I can’t imagine I’m the only one with this issue. Can someone help me?
the app will record all sounds with volume louder than the set threshold.
So if the app keeps recording the TV, you might need to adjust the recording threshold in Settings > Sleep noise recording > Recording volume threshold (set it to lower sensitivity).
Each environment has unique acoustic, and level of non-related sounds, so it is possible the default values are not a perfect fit for your needs.
Thank you so much! Very helpful! I will set it higher tonight.
