Can you PLEASE add the option to make the background transparent for widgets?
With Smart Launcher, one of the newest features is “glass” backgrounds.
So long as you can make the background transparent, you can effectively make that widget adaptable to any theme you want to use. You can make a blank notes widget that mimics the theme, then overlay your desired widget.
Example and comparison with the current Sleep widget background:
support conversation with Dustin
