Track my REM
From Susan Gibbons on 2014/12/29 15:05:45 +0000
I would like to suggest being able to see the time spent in REM sleep each night. You already do that for deep sleep, snoring. I’d like to keep track of my REM sleep in a similar fashion. Seems easy enough to add to stats
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6897750-track-my-rem
From Susan Gibbons on 2014/12/29 20:41:27 +0000
thanks for the info, I thought maybe since you have a category called 'REM', I could just get a total of that 'estimate'. I understand your point though.
