If you’re a TIDAL user and rely on your Apple Watch for music, you might have encountered the frustrating issue of TIDAL stopping after playing just one or two songs. Don’t worry! In this blog, here are some fixes you can try to resolve the issue. Let’s dive in!
Fixes to TIDAL Stopping on Second Song
- Check Your Connection
- Ensure your Apple Watch is properly connected to your iPhone or Wi-Fi.
- Disconnect and reconnect Bluetooth headphones to refresh the connection.
- Update the TIDAL App and watchOS
- Update the TIDAL app to the latest version from the App Store.
- Go to the Watch app on your iPhone to update your Apple Watch’s software.
- Re-download the Tracks
- If the issue happens with offline tracks, delete and re-download them directly on the TIDAL app for Apple Watch.
- Restart Devices
- Restart your Apple Watch and iPhone to clear temporary glitches.
Ultimate Fix: Download TIDAL Music to Your Device
If general fixes don’t work, the issue may lie with how the tracks are downloaded. To avoid playback problems, you can download TIDAL music to your computer using a reliable TIDAL music downloader. And then, you’re free to transfer the downloaded tracks to your Apple Watch, or other desired devices.
One of the best tools available is a TIDAL to MP3 converter like ViWizard TIDAL Music Converter. This software allows you to:
- Download TIDAL music to your computer without restrictions.
- Convert TIDAL to MP3, AAC, or other popular formats for seamless playback.
- Transfer your converted files to your Apple Watch for offline listening without errors.
Conclusion
TIDAL stopping on the second song can be frustrating, but with the fixes above, you’ll be back to enjoying your playlists in no time. For a guaranteed solution, consider downloading your music to a computer using a reliable TIDAL to MP3 converter like ViWizard. It’s a foolproof way to avoid playback interruptions and enjoy TIDAL wherever you go—even on your Apple Watch.
