From Anonymous on 2017/02/28 18:22:23 +0000
There are a series of device called ticwatch 2, made by Chumen Wenwen company.
It has HR sensor, acceleration sensor, mic, speaker and vibration abilities. It would be functioning great of there’s a Sleep as Android wearable add-on port for it.
However, it’s nessesary to mention that although it has Android Wear API, it’s an alternative version especially for China, which is not quite the same compares to the original one.
API docs and SDK of that custom-made Android Wear can be found here: http://bring.link/ticapi (a short address site by myself, you will be redirected)
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/18476749-ticwatch-wearables
