Thermometer (axillary)
From Janis Froehlig on 2016/06/05 16:31:28 +0000
This is a longer-range idea/request.
My sleep doc said she could peg (clearly define) my circadian rhythm by getting my temperature at minimum 2-hour intervals. There are some baby-oriented bluetooth axillary (arm pit) thermometers available, but obviously I can’t integrate that data into SaA, (nor do the tiny straps fit around my arm).
It also is looking like the software for these is sketchy/cheap/unreliable, as well as a few instances of the hardware.
I would happily chase this idea down myself, but I have no idea where to start/whom to contact, so, well, here it is.
(Once I got the mask properly clipped, I’m loving it!)
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/14659311-thermometer-axillary
From Janis Froehlig on 2016/06/14 09:47:00 +0000
I bought this one: http://www.alibaba.com/product-detail/2015-New-Children-iFever-intelligent-wearable_60420314570.html?spm=a2700.7724857.29.209.WNUxDb . It was supposed to be delivered yesterday, but my post office missed it. I'll be picking it up today. I'll let you know how it goes.
From Janis Froehlig on 2016/06/06 17:53:43 +0000
a bit more helpful: http://www.alibaba.com/product-detail/2015-New-Children-iFever-intelligent-wearable_60420314570.html?spm=a2700.7724857.29.209.WNUxDb
It just needs a longer strap. It would be cool of you could get the accent color in Android Green. :slight_smile:
From Janis Froehlig on 2016/06/06 17:47:53 +0000
I'm in Minnesota, US. There are several medical device manufacturers here. I'm happy to contact them (or not) if that's the path you want to take.
I'm not having much luck finding the Chinese manufacturer for the Amazon-available products I linked.
From Janis Froehlig on 2016/06/06 17:32:26 +0000
It seems they're all Chinese. This also came up on Amazon.uk:
http://www.amazon.com/Jieweixin®-Temperature-Intelligent-Thermometer-Bluetooth/dp/B01GBI5R4I/ref=sr_1_9?ie=UTF8&qid=1465234193&sr=8-9&keywords=Jieweixin
Definitely clunky for wearing.
From Janis Froehlig on 2016/06/06 17:21:46 +0000
I should say, too, there are many weather monitoring devices that would, though not comfortably, probably work. There are many manufacturers of these.
From Janis Froehlig on 2016/06/06 17:18:31 +0000
From Amazon.com:
This is the most expensive one: http://www.amazon.com/Infanttech-Award-Winning-Thermometer-Monitor-Temperature-Smartphone-Apple/dp/B018UGEG1O/ref=sr_1_17_a_it?ie=UTF8&qid=1465233051&sr=8-17&keywords=bluetooth+thermometer
Here is one of the cheaper ones: http://www.amazon.com/Wireless-Thermometer-Bluetooth-Temperature-Intelligent/dp/B015Z7J0EY/ref=pd_sim_75_5?ie=UTF8&dpID=311RMsvaeHL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1A9NMDKZ7SCCXSFQH3CM
This is the cheapest, but the listing isn't clear and the seller wasn't responsive to my question:
http://www.amazon.com/Foxpic-Thermometer-Intelligent-Temperature-Bluetooth/dp/B01CZRLMSE?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_4&smid=AWQQT9Z150KCX
This one has a lot of sellers/brands for the same item: http://www.amazon.com/Bluetooth-Intelligent-Thermometer-Temperature-Smartphone/dp/B01E9US27O?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_3&smid=A228X9FCLLPZ6D That indicates there's a manufacturer who isn't retailing them. I will try to find out who that is.
They all have their proprietary apps.
