I prefer my theme to be Night Owl (dark mode) so whenever i bring up the app in a dark room to turn it on it doesn’t light up the whole room or wake my spouse up. However ever since I got the One Plus 7 Pro a couple months ago, every time after a reboot the first time i launch the app it is still in the original “Morning Lark” (light mode) theme, although if I go to Miscellaneous → Theme : Night Owl is still the one selected. To resolve I can either :
- Change theme to Morning Lark (or anything else) then change back to Night Owl (Automatic Bedtime works too)
- Or goto my app switcher, swipe up on the app to kill it (and since I’m using a One Plus device w/ WearOS HR tracker I have to unlock the app from memory first), and then relaunch the app. So killing it/launching it a 2nd time after a reboot and it restores the correct theme.
It doesn’t matter if it’s locked/unlocked before the reboot/issue. It doesn’t matter if I’ve killed the app in memory (so it’s not in my app switcher) before the reboot. Every time though it’s reset back to stock the first time I open it up. I’ve used SAA for many years and I’m fairly positive this issues started as soon as I got my 1P phone, so it’s probably limited to it.
Steps to reproduce:
- Have a 1P7P
- Install SAA
- Change theme to Night Owl or Automatic Bedtime (and try it in the evening)
- Reboot phone
- Reopen SAA and see theme is now Morning Lark.
Latest Beta 20190830, but all versions for the past couple months.
Android 9, Oxygen OS 9.5.11.GM21AA
Thanks!
