Testing sensor - Sleep as Android
During the Test sensor, the app connects to the selected wearable, confirms the proper connection and then shows you the detected movement.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//devices/test_sensor.html
