From Paul on 2016/01/09 19:16:48 +0000
Add an option to automatically tag the sleep with the name of the connected wifi network. This would be more useful than geotags for me.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/11364405-tag-with-connected-wifi
From Robin Markowitz on 2016/01/18 03:06:32 +0000
Yes! To me, that's actually an issue I'd like to resolve. WiFi is off during tracking. I think that when you terminate tracking in the morning, the app should immediately trigger your strongest WiFi signal to get weather (and traffic) right then. It has a "weather" option, which can't be used if WiFi is off.
This could be another element of Google Now integration. This way, the app need only trigger Google Now cards to pop up. For everything in the early morning. Thanks for your consideration.
