Suunto watch integration? [Ambit3, in my case]
From Garrett Breit on 2017/03/02 00:54:55 +0000
I was wondering if you’d ever taken a look at Suunto watches for sleep tracking?
They make some powerful devices. I have the Ambit3 Peak, and I wear it constantly. It would really be awesome to have it integrated with your app, as having the phone in my bed with me really wasn’t working well (I’d knock it off, and/or accidentally disconnect it from the charger). I’ve really missed the smart wake up and the sleep metrics that I used to get.
Suunto opened up the ability to develop “apps” for the watches (that store/run on the watch). http://www.movescount.com/apps
Suunto’s watches already have Bluetooth 4.0, a decent built in accelerometer, 24/7 activity level track/graph, and can store quite a bit of data. Their apps also look like they apply to all Suunto watches, so you could likely get connect to quite a few people with one.
Thanks for all your hard work!
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/18491371-suunto-watch-integration-ambit3-in-my-case
From Garrett Breit on 2017/03/02 00:57:49 +0000
Sorry, edit on the last line, you could get connected to many users with minimal variation between watch series.*
The Suunto Smart Sensor is BT .
