Please integrate with Suunto family watches.
Suunto integration
Plus one for this, integration into the Suunto ecosystem would be great.
Hello @Chris_Laidler @Radoslaw_Matejko ,
unfortunately this device does not provide the required integration options. The device needs to have an API that grants access to adhoc sensor data. Please correct me if I’m wrong, but I believe this device does not have such API.
Anyway if there is anyone willing to reverse engineer the BT protocol and do some integration, Sleep as Android has an open API so anyone can integrate any device with Sleep as Android although we do not have the resource to go this way. Please check our doc on our wearable API here:
Currently we have integrated with Android Wear devices, Pebble, Gear, Garmin and a few others. You can watch our current integration progress here:
