From Leo on 2016/01/04 07:50:05 +0000
Would be awesome if you could integrate with Vera. You could create a simple plugin where sleep as android is listed as a device. Thus, whenever you set your alarm that device triggers and the possibilities are endless for integrating with home automation. Vera is the leading platform for home automation using zwave and has a large community around it. It has native support for almost every system out there, including hue bulbs, milight, sonos, etc. If you integrate with them, it could then tie with every other system without having to do anything else!
Links
Company Homepage
Plugin Creation Intro
https://dmlogic.com/blog/developing-z-wave-plugins-for-vera-with-lua-and-luup
Plugin Intro from the Vera Wiki
http://wiki.micasaverde.com/index.php/Luup_Plugins
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/11298801-support-vera-home-automation-system
