From Peter Karsten on 2016/06/05 14:50:56 +0000
Thanks for the great work to realise SPO2 integration via Berrymed Devices.
See:
http://sleep.urbandroid.org/documentation/extended-features/apnoe/
It would be wonderfull, if you can realise the option, to use the cable Version of berymed SPO2.
See:
Can used via OTG on Tablet and smartphone.
Because of too much radiodata in the sleeping room, i dont want to use so much Tranceivers for the wonderfull SaA App.
Thanks
Peter Karsten
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/14657520-support-for-berrymed-cable-version-devices
