Sometimes SAA shows me awake during a time I know I was asleep.
Being able to override the Awake in the graph would be nice, or even if you could cut or delete an awake And Then go to Add Sleep
and add sleep in the slot you just deleted or cut (instead of getting the error that says you can’t because data already exists).
Or your could select a section of an awake in the Edit Graph and select “Change to Awake” where now, well changes that section for. Awake to Asleep. Maybe have the bar in the graph a different color…
Hello @ima_jenn, sorry for the issue. If you send the menu > report a bug I can see which of our awake heuristics did cause the false positive.. You can check Settings > Sleep tracking > Awake and fine tune the sensitivities for each heuristics..
Now there is an option to delete all awakes and you may than re-enter only those which are properly detected.. We know this is little cumbersome so we are preparing a feature which lets you delete awakes only in your current selection…
Hello @ima_jenn.. in the latest BETA I have added an option to add / delete awakes only withing a certain selection on the graph, would you be willing to give it a try?
Redirecting to Google Groups you can opt-into the BETA at the following address:
YOU DID IT! Full editing power! MANY THANKS!
All my best,
Robin
@Robin_Markowitz big thanks :).. very much appreciated!
