After you enable Spotify in Settings → Services, Sleep as Android will connect to your Spotify account to be able to download information about your saved albums and playlists. Then you can set up one of those as your alarm’s ringtone or lullabies. See Ringtone.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//services/spotify.html
