From Nikolai Ommundsen on 2017/01/27 23:12:01 +0000
Trigger the alarm if the phone is discharging and very low in battery. This would be useful as you’ll not miss the alarm. It is good to have a feature like this if the power is out or if you pull the plug while sleeping.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/17868562-sound-an-alarm-when-the-battery-level-is-low
From Nikolai Ommundsen on 2017/01/28 18:15:46 +0000
I've had issues with the power in the apartment shutting off during night and the phone discharging. And also by simply forgetting to plug in the charger. I've overslept many times because of this. I'll be really happy if you can make an option.
