Sony smartband talk sw30 integration
From Fabio Bucchieri on 2015/02/23 14:07:19 +0000
Now that lifelog api is available it should be possible for you to pull sleep data from it and adapt them for your app.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/7131467-sony-smartband-talk-sw30-integration
From Arturo Romero on 2015/05/03 09:00:07 +0000
I'd rather use Sleep instead of Lifelog for sleep tracking, but, if it is accurate, I prefer having the wristband record it instead of shoving my phone under the pillow. If we had integration I'd turn Lifelog's sleep tracking off and just use Sleep. But I understand that it isn't a priority. I'll be using only Lifelog for a while and maybe I'll keep using both after.
