Sonar Tracking Not Detecting Movement Properly
I’m trying sonar tracking, but it doesn’t seem to detect my movements correctly. The sleep graph often shows very little movement, even though I know I’ve been tossing and turning. Are there specific placement tips for my phone to improve sonar accuracy?
Hi @harryclinston, if you go to Test sensor, what number do you see as the signal strength after the sensor calibrates?
You can also use the Left ≡ menu → (?) Support → Report a bug, and send us your logs. I will check what the data set looks like.
