I’ve used SaA with sonar and HR sensor, and everything worked fine.
Until I connected mi band 6 using Notify app(both AppGalary and play store versions tried). Now sonar does not work, during sleep recording(I could not hear it at all, like before).
Hypnogram is null, only wake-up data.
Reinstallation of SaA and notify doesn’t help either.
Steps to reproduce:
Use sleep tracking with sonar and mi band connected with notify(sensors test in notify is ok)
Not hearable. But hearable while sensors test in settings.
2024.07.01 (230436) 34
Xiaomi Redmi Note 9 Pro
Android 14 AOSP
App is not killed
