We have reports that this can happen on some devices, this depends on how the device mixes audio channels.
This is a companion discussion topic for the original entry at https://docs.sleep.urbandroid.org//faqs/lullaby_sonar_audible.html
EDITED MERE MOMENTS LATER TO ADD.
Hi. I’m a long time (10 yrs) apparently very dumb user of your awesome app.
The sound I was hearing was the constant PING sound as the power flow was interrupted continuously to the phone charger due to a not-totally-plugged-in-all-the-way charger. My bad. Lesson learned: always check the charger.
So then never mind my “issue” wasn’t an issue at all and don’t bother reading the middle. Just the beginning and the end
And now time to go to bed.
Hi. I am a long time (10 yrs) user of this app. Its terrific.
I updated my os (pixel 4xl) when the most recent update was issued (Oct 15). This sonar chirp was never something I heard prior to this os update.
I do appreciate your suggestion of looking at the sensor settings, however there are no options for turning on/off sounds. And when using the accelerometer, there are not even frequencies to navigate. So I was glad to see this post existed but it does not contain an adequate solution to the problem…
I would greatly appreciate if your team could look into this? (I am someone who has purchased add-ons if that helps lol)
Sincere thanks for a stellar product with this only one new (yet seriously annoying) issue that is keeping me from sleep as android.
You guys are terrific! Thanks again!
