If I activate a snooze, the ringtone and the light go off until the end of snoozetime and starts again. But in real the sun would not turn back behind the horizon.
It should STAY ON if I activate a snooze, not start again with the end of snooze.
And I hope it’s possible than that the light go on to grow up gently (how I choosed it in the sound option). OR at least stay and wait in the actual sunrise position until the next snooze alarm sound starts.
(There are so much possibilities with hue and Sleep as Android. You can get it! great work!)
It would probably be easier and more user-friendly to make this a toggle in the smartlight settings than expecting people to set multiple alarms with different loudness and snooze settings.
Yes I would love this feature! Just got the Hue smart-lights and am pretty disappointed that you cannot keep the light on during snooze cycle. Not sure how a different app or a second alarm would work with the smart wake up feature either.
This feature was added in the August 30 update. Go to settings > smartlight, and set “light up after” to “both”. This causes the artificial sunrise to ignore the snooze button.
Thanks for adding the feature. However I am not it is working as intended on mine. I have it setup at both which keeps the light on after I click snooze or turn off the alarm which is good.
However, the light turns off and restart the sunrise cycle after the end of the snooze period when the alarm starts again. This is not desirable for me. Like it was said before, the sun would not go back below horizon Haha. It would be ideal if there was another toggle preventing that or just changing the logic to avoid that. I don’t see why someone would want that. Thanks in advance!
Bug still exist after more than a year.
When selecting snooze the Hue light will stay on and don’t switch off.
Keep light up after is set to “never”
If this worked as designed I would like to have the settings option to allow automatic switch off function.
Still have this problem in Jan 2021 the snooze keeps the light on if you have it set to both but as soon as the next snooze alarm goes off the lights dim back to sunrise and it starts the process all over again putting the room back in the dark.
