From Anonymous on 2014/10/20 04:27:35 +0000
Add options for smartlight activating X amount of minutes before alarm time.
Also for smartlight not to turn off when snoozing.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/6583869-smartlight-options
From GM on 2015/05/20 16:53:29 +0000
This options would be great
From Petr Nálevka on 2015/04/18 21:07:55 +0000
+Johannes I understand.. as a workaround for now you could use some nature sound which will sound ok even at high volume as the backup alarm..
From Johannes Russek on 2015/04/18 16:40:56 +0000
Just found it, if it plays at maximum volume immediately that'd be not so nice ![]()
I'd prefer the "okay now you gotta really wake up" alarm sound to gently increase as well.
From Johannes Russek on 2015/04/18 16:39:48 +0000
Hi Petr! So basically the same I do it right now but instead of just adding a second alarm I'll use that backup thing? I'll have to try!
From Petr Nálevka on 2015/04/18 16:22:34 +0000
Hello Johannes, there is an alarm backup feature to make sure you get woken up and you can use a silent alarm with only light, would that work with you?
From Johannes Russek on 2015/04/18 09:40:15 +0000
I would totally love this. Right now I have to set a second silent alarm to start the smartlight before the actual alarm goes off. Most of the time it's enough to gently wake me up, but sometimes I need the extra alarm sound.
If I don't need the sound though, it's super pleasant to be woken up like that!
From Jason on 2015/02/02 13:15:01 +0000
Thanks for submitting this. I'm looking for this feature too! I don't get why snooze turns off the light - the whole point of the smart light is to try to help the body wake up more naturally.
