I’ve been working on this issue for about 2 months. No matter how I setup my alarm configuration, all the lights in my house come on with the alarm instead of the lights I select. When I hit the Test button only the selected light(s) flash, but when the actual alarm goes off all the lights in my house fade on.
Steps to reproduce:
Setup alarm with Philips Hue connected. Select any configuration of lights to use for the alarm. Test to make sure only those lights flash. But when the alarm goes off and the light intensity increases, all the lights in my house turn on and fade in at the same rate expected by the lights I intended to use.
20190411, but it’s existed on every version I’ve had installed.
