From Nick on 2017/06/15 06:02:42 +0000
Idea is… User can change the colors, brightness ect and adjust pee light also… For my personal thing the pee light is not bright enough for me but I got three smart lights in the bedroom…
Next idea… I got a few OSRAM lightyfi plugs… I connect one to the bedroom lights… So my alarm goes off two lights get bright and the coffee Maschine comes on
Problem is if you forget to put water in and coffee in it’ll still comes on…
Wouldn’t it be great if u start your sleep mode it’ll ask u if u want coffee or not and u click yes or no and it adds a plug or not
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/19599274-smart-lights
