From Oliver on 2018/02/01 15:22:19 +0000
At the moment Smart Lights feature is used on every alarm if enabled (globally). So if I am sleeping in another room the Smart Lights in the configured room are triggered. Smart Lights triggering should be a setting per alarm (on/off or even specific lights).
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/33167332-smart-light-configurable-on-off-per-alarm
