I want to keep track of the hours I am sleeping, so I wanted turn the app on when I go bad and turn off when I wake up. But I do not want sound recoding. Is there any way to do it?
Thanks in advance.
Hello, the sound recording is optional and will work only when enabled in your settings: Settings > Sleep noise recording > Enabled - here you can enable or disable this feature
Hi Lenka,
Thank you so much.
Donno how I missed it, but it was right there and easy to find.
Thank you for your help.
