I use multiple alarms to wake up which usually differ by 5 to 15 minutes. Most of the times I do not wake up on first alarm. However, the sleep tracker stops after first alarm. Is there any way to track my entire sleep?
Just set the alarms to not stop tracking when the alarm goes off.
I.e . for each alarm: Check the settings for that alarm: <three_vertical_dots_icon) -> ‘Alarm’ settings page -> Miscellaneous -> untick ‘Terminate tracking’.
This way SaA will continue to track and when the last alarm has gone off, you manually stop the tracking.
