From Philipp on 2016/09/01 08:27:49 +0000
Hello, I do not need the sleep phase tracking and like to use the sleep noise recording only. I like to disable the sleep phase tracking function to save battery.
Copied from original feature request: http://urbandroid.uservoice.com/forums/264867-sleep-as-android/suggestions/15889000-sleep-noise-recording-only-option-to-disable-sle
From Philipp on 2016/09/02 22:55:40 +0000
Thanks Petr for your feedback. So then it is the same to lay the phone on the table near the bed. 1-2% is not so much. ![]()
